weird noise sounds like brakes grinding metal
Guys/Girls I am totally new to all this forum / club stuff and internet
I have just bought a BMW E88 1 series had a worn out brake metal to metal sound seemed like from the  rear of car on complete removal and cleaning I find both front and back brakes are all new both pads and disks and after cleaning its made no difference  at all only other symptom is it only starts making noise after 20mph and its a continuous noise but doesnt seem to get faster or slower
any help please anyone I would be most grateful
Morning Terence
When checking the brakes did you check the handbrake shoes ? Other things to check, I have seen brake back plates rubbing and heat shields rubbing so check they are secure
Check there is nothing touching the drive shafts and prop, if it is still there wheel bearings and Diff need checking
Hope this helps
thanks for answering mate yes checked handbrake shoes i totally stripped each wheel to nothing re-copper greased and put back made not a slight difference
ok thanks will check today
  • 4 weeks later...
Have you checked the weather protection plate(s) behind the disks are not catching the disk?
