Bmw 7 series G11 2017 730d gearbox problem.
Greg1122
Hi guys, my 7 series developed some gearbox issue. When car is cold, when it goes to reverse it dosent move, I have to rave it up to 3000rpm fot it to start moving, and even the it jast barley move. Going forward is ok, but every gear change is with judder.
Now when you drive it for 15 min and everything worms up it drives like new.
Do you know any reliable automatic gearbox specialist around Hampshire?
But I'm willing to travel bit further if needed.
Thank you in advance.
Morning Greg
Google ZF Specialists in your area that is what you need. The gearbox should be serviced every 60 to 100k depending on use and sadly they rarely are.
I have heard good reports about Solent Gearbox's in Southampton though not used them myself
  • 5 months later...
Morning Tony
Sadly many never close out their posts when the problem is fixed
Find a good transmission specialist (preferably ZF) and get the box serviced they will tell you what the problem is. Gearboxes like engines should be serviced but rarely are Good Luck lets hope it's a simple service job
Morning Peter
You don't say which model you have most BMW's will have a ZF box (Manual or Automatic) though some models use an Asin Warner box
A lot of 5 speed ZF auto boxes suffered the dreaded clonk/lurch when slowing or coming to a stop. Most could be stopped with a service and software update. Of course all mountings and drive shaft are in good condition
    4. 13
    5. 13
    • Kiernan earned a badge
    • phil angel earned a badge
    • jon green earned a badge
    • bill gall earned a badge
    • kor earned a badge
