Bmw 525d f11 towbar problems
Markus Kleppe
Morning Markus
All clean underneath nothing jamming it ? What is the Error Code ? Have you checked it online ?
I would check all wiring and connections, fuses and relays, then make sure that the mechanism isn't blocked or jammed then clear the code and see if it works. A diagnostic session will help if your stuck
Morning Markus
Sorry that isn't a code it is only the cars display warning.
To begin with have the fuses been checked? Check the fuses if they are OK then you need a proper diagnostic session to identify the problem.
I have seen 1 failed trailer control unit and 2 failed gears in the folding motors (one on my own X5)
All 3 I was able to fix by sourcing replacement a replacement control unit, and stripping and rebuilding the folding motors.
    2. 12
    3. 12
    4. 5
    5. 5
    • phil angel earned a badge
    • jon green earned a badge
    • bill gall earned a badge
    • kor earned a badge
    • Damion earned a badge
      Reacting Well
