520 D Tourer dashboard warning
Ivor Rushforth
My 2017 520D Tourer has thrown up a warning alert recently and wondered if anyone had experienced the same and discovered the cause.  It says, Chassis function restricted.  Possible to continue journey. Have the problem checked by your service partner.  Suggestions and ideas or previous experience gratefully received. Thank you
Morning Ivor
Could be a number of things from a sensor to a damaged part you really need a Diagnostic session using a BMW capable system. So a BMW Dealer (£££) a BMW Specialist (££) or good Independent Garage (££)
BMW Dealers will be more expensive on an Hourly rate (someone has to pay for the free coffee 😅) BMW Specialists tend to be less expensive as do good Independents, there is a Register of BMW Specialists so you should find one near you or possibly a member near you who has the kit at home and is willing to help.
  • 6 months later...
      Engine cut-out on idle.
      Amplifier replacement.
    5. 3
    • Sbannas earned a badge
    • Allan Wilson earned a badge
    • Danny428F33 earned a badge
      Reacting Well
