Air con on 2006 mini one not working
B Mini
Hi John
If your lucky it just needs a re-gas if your not lucky and it needs parts due to leak it could cost a bit.
If you brought from a Garage/Dealer tell them and see what they say (they ought to fix it)
If it was a private sale it's tougher, Kwik Fit often do Air Con Re-gas deals worth giving them a try the machines they use vacuum out the system check it holds a vacuum so will only re-gas if there are no leaks. All Aircon systems loose a little each year particularly if the previous owners turned it off for lengthy periods. Bad practice the seals dry out allowing gas to leak.
Hope this is useful
      wheel fitment
      wheel fitment
    5. 2
      wheel fitment
    • hermit earned a badge
    • Robbawdie earned a badge
    • Neil Mason earned a badge
    • Stuiggy earned a badge
