BMW 128i Xenon Eagle Eyes Flickering Issue
Hey
BMW 128i 2013 (E82)
I had upgraded original lights to Eagle Eyes Bi-Xenon
Everything was fine for years
I made accident and had to replace right side
I ordered the same part number as the light before - BMW 7273831-03 Valeo
But the problem is that right light is flickering (not the one I replaced)
It is random - it can run 10 minutes without flickering and then flicker
If I switch lights off and turn it back on xenon lights do not work
Sometimes it does work
What can be the issue and how can it be resolved?
Quote
Morning Nathan
A little confusing above you say you replaced the right light and the right light is flickering but not the one you replaced?? A quick look at Realoem tells me the part number was for the Left hand lamp. Is it the DRL (eagle Eyes) flickering or the Xenon Headlamps. Flickering could be a failing lamp (Bulb) or an issue with the Control unit
First check all the connections pay attention to the Earth points both sides the Xenon control units are high voltage so if you don't know what your doing get either a BMW Specialist or Auto Electrician to help. A Diagnostic scan may help as well.
Hope this helps
thanks im adding videos
its very random
Morning Nathan
From the 1st video it seems the right hand outer lamp is flickers but the left (drivers side) is out
2nd video left lamp is on but after restart not
Have the Lamps (bulbs) been changed/checked? It looks as though that is where the issue is
I would check all connections make sure all connectors are fully home same with the Lamp (bulb) connectors
If connecters are not home how come lights are on for sometimes 3 minutes ?
same with bubls
technician told me if bulb had issue it would not even turn on
very confused
If a connector is not fully home or has a poor connection vibration can cause intermittent contact.
A lamp (the Bulb) can suffer the same sometimes a lengthy period before total failure
Did the technician suggest a cure ? Was the technician a BMW one ?
If you turn on the ignition don't start the engine and turn on the lights what happens with out vibration.
If I turn on ignition and put lights on - sometimes they turn on sometimes they dont - and still flicker
i still haven't gone to official bmw technician because xenon are manually upgraded by me
OK so when you upgraded to Xenon did you use OEM parts or Aftermarket? If the parts are OEM are they correctly coded to the car? If not that is probably where the issue could be, the other culprit is in the wiring I know from helping several people who upgraded 5 series to LCI lights that often the correct connectors are needed and poor modification of the lighting loom was often a nightmare to correct.
With your conversion you probably need a wiring modification to the Earth plus an inline resistor to stop flicker. I have also read that the Light switch may need changing, in earlier cars the FCM may need changing and re-programming. If you are OK with DIY on your car and know how to use a Multi Meter you should be able to sort it. You will need either a laptop with INPA/ISTA diagnostic software on it or the help of someone who has if any coding/programming is needed.
Thanks for the help Greydog
I switch both Headlight Bulb and it solved it
Philips 85415VIC1
