Dtc light on
argrdnr
hey all
couple issues here, hope someone can help
2008 120d
1. Just had the brake pads, discs done and pad wear sensors done - how do I remove the warnings on the dash?
2. Got the dtc/dsc light on after driving in rain, how do I remove this light (as pictured)
Β
thankyou πŸ™‚
Morning Adam
First make sure the pad sensors are connected correctly, looks like you have a rear Fog lamp out as well. To reset try disconnecting the battery (Neg first) and leave it for 15mins then reconnect that should reset everything if it doesn't then those faults need further investigation.
I don't think so the radio has its inbuilt memory otherwise dealers would be in a real mess
I understand they are new discs and pads but are the sensors connected correctly?
Try the battery disconnect first if the DTC fault comes back you will know
Β
Correct Adam, some folks touch the 2 disconnected leads together they say to discharge any static. Personally I have never done that so can't comment on if it works.
After reconnecting and starting drive slowly forward going lock to lock to reset the steering angle sensor.
    2. 14
    5. 14
    • Kiernan earned a badge
    • phil angel earned a badge
    • jon green earned a badge
    • bill gall earned a badge
    • kor earned a badge
Γ—
Γ—
