BMW E63 635D GEARBOX RATTLING / KNOCKING
Chlooxo
Hello,
I was just seeing if anyone knew what the issue could be with the gearbox? When it is in park or neutral it’s making a rattling / knocking sound, but doesn’t do it while in drive or reverse.
Bmw 635D 2008.
Thanks!
Morning Chloe
First are you sure it is the Gearbox not something loose like a heat shield if you can't get underneath to check then you will need the help of someone who can.
If there is nothing loose rattling then it could be something to do with the Torque converter as the gearbox is not turning in neutral or park.
Hope this helps
      Front windscreen washers
      wheel fitment
      wheel fitment
    • Loulou earned a badge
    • hermit earned a badge
    • Robbawdie earned a badge
    • Neil Mason earned a badge
