How to reset brake service light
I have a f40 m135i x drive and have just changed front pads as the service light came on. Can anyone tell me how I can reset my brake service light on my dash board thanks mick
Morning Michael
Try this,
  1. Turn the ignition to ON and press the odometer reset button located on your dash.
  2. Hold down the button. Your display will show a yellow triangle with an exclamation point inside. Then, it will enter the service menu.
  3. Use your turn signal stalk to find the brake light setting.
  4. Press and hold the BC button on your turn signal stalk to reset the light.
Hi dave thanks for rhe reply.
Unfortunately I have the screen with no odometer button to be able to push in and reset. Its all done by going into the menu on the idrive.
2020 plate f40
Try this
  • 1. Without pressing the brake/clutch, press the start/stop button
  • 2. Wait for the service reminder to disappear
  • 3. Press and hold the odometer reset button. ...
  • 4. At the value you want to reset, press and hold the odometer reset button. ...
  • 5. Press and hold odometer reset button again until value is reset
Thanks I have no button below the speedo .I have looked on you tube and I've tried them all start stop quick 3 times then press b.c button .to show menu.no brake reset just the brake fluid and oil reset .
Mick
I've tried that and nothing no brake pad reset. Mick
They might do if I asked at a price.they wasn't amused when I said I was doing the front brakes myself.
I know what you mean, when I upgraded the Front Callipers  on my X5 4.6is to Brembo the service manager looked down his nose and asked me if I realised my front callipers were "non standard" and incorrect so could be unsafe??
I asked him why BMW used Brembo on their competition cars ? He gave a condescending smile and walked away, that was 2004/5 he still doesn't talk to me leaves me to his colleagues.
Find a good BMW Specialist there is a Register so you should find one near you
Thanks alot for the replys. I'm sure
there is away to do this if I find out ill post it on here. I'm more than certain that in years to come most of us will be doing our own maintenance on cars.
Mick
