Suspension help needed please.
Moggy
Can you help please. My e70 has been suspended on ramp for about 3 weeks with the wheels off. Today I took it off the ramp and the rear suspension is at its lowest on both sides. Not only that but the compressor is not coming on. I have checked the dashboard 40amp fuse and the 10amp in the boot but all appears well. Does anyone have any suggestions as to whats gone wrongring. It worked perfectly well prior to going on the ramp.
Thanks
Morning Duncan
Have you removed the fuses and checked them or visually inspected them? Is there power at the compressor? What information is the car giving you through the On Board Diagnostics?
Check the level sensors are OK not sticking the knee joint should be pointing towards the wheel I have seen where the suspension has been fully or overextended, they fold the wrong way, so nothing works
If Fuses Relay sensors and controller are OK then the compressor may have failed. A Diagnostic session will tell you for sure
      Folding mirrors
      Centre console iPhone charger
      Folding mirrors
    5. 3
    • Damion earned a badge
      Reacting Well
    • Stuiggy earned a badge
    • Penguin82 earned a badge
