97 Z3 rear wind deflector
Morning Tony
I know there are Roll Over Protection hoops as I have helped change some on the same model you have for a friend of my brother inlaw, Not sure about the wind deflector though
I would take a look at www.realoem.com if you are not aware it is an online parts list for all BMW models. Just put the last 7 digits of your Vin into the search box it will call up your model (in the classic section) then go through the sections Hood/Top and Trim sections should have information about what you need. It may be worth looking at early Z4 models as well (search manually) as often around model change mounting points may well be the same. Make sure you measure carefully if looking at this solution before parting with your hard earned.
      Coolant leak
      Coolant leak
      Coolant leak
    4. 5
      2e47 & 2e41
    • Kev Miller earned a badge
    • Jeags earned a badge
    • olly530i earned a badge
    • StuMc earned a badge
