Hi Florian
Can you not re-bush the trailing arms lots of Poly Bush kits available, or is the issue rust?
Rust unfortunately and have been told it cannot be welded for MOT reasons. Having no luck with eBay etc.
Damn the tin worm
Have you tried the BMW specialist Dismantlers like Quarry Motors (they have helped me a couple of times) Google BMW Dismantlers there are a number in the UK
Is it the Sub Frame or the trailing arm ? May be off the car a specialist Fabricator could help ? We did this with a friends W210 Mercedes
An after thought have you talked to BMW UK they have a Classic's section
Hi Dave,
Thanks for that still no luck unfortunately.
it is the trailing arm which comes as one part with hub assembly etc.
BMW UK are quoting £1200 for a new part. Have been told a used part should be around £150. So would like to avoid if possible!
surprised that there isn’t anything aftermarket available!
Florian
18 hours ago, Chu346 said:
You want the drivers side rear on a right hand drive car?
Yes! Seems like RHD and LHD parts are interchangeable however.
Florian
Florian
I have a pair that I was hoping to get powder coated that I may split.
when do you need them by?
Was really only after the right side but if you need them gone as a pair I’d be happy to take both.
After them as soon as possible really the poor thing has been off the road for a month!
Florian
    2. 17
      2011 X3 radio reset
    4. 17
      Pure oil in coolant tank
    • StaffordSteve earned a badge
    • ndsim earned a badge
    • Ken C earned a badge
    • stehay123 earned a badge
      Collaborator
