X1 oil leak using oil
Hi every i recently had a dpf delete and remap,since that my x1 has been using alot of oil grey blue smoke and oil is dripping from tailpipe,I think there is a leak in engine bay on drivers side πŸ€” any ideas πŸ’‘Β
Morning Kevin
If oil is dripping from the exhaust then it has bypassed the combustion process as that much oil would have left a cloud like a special effect in a Harry Potter movie.
If you can't investigate the leaks yourself you need the help of a Mechanic or Garage who can.
As for a guess at what or where the leak is my vote is badly worn turbo, but whatever it is it needs addressing fast.
As for DPF delete you are aware that next MOT you could have a fail ?
      Tapping
      Engine cut-out on idle.
    5. 3
      Amplifier replacement.
    • daniel syd earned a badge
    • Sbannas earned a badge
    • Allan Wilson earned a badge
    • Danny428F33 earned a badge
      Reacting Well
Γ—
Γ—
