Manually open the boot/trunk
Kelvin uk
Morning Kelvin
There is normally a manual/emergency release pull check your handbook for it's location
Or you could try connecting a batery to the charging points under the bonnet see if it allows the central locking to work
Morning Kelvin
I think in the boot the fuse panel there will have a fuse location diagram folded up in the holder
Most BMW's have fuses and relays behind the glove box and in the boot and a panel in the engine bay. All I can tell you is the X5 wiper fuse is 37 in the glove box panel there is also a relay (probably your issue) all you need is the 3ft long multi jointed fingers of a Bavarian Gnome that can grip like mole grips and it's simple 🤣
Check for the layout diagram in the boot
    4. 13
    5. 13
    • Kiernan earned a badge
    • phil angel earned a badge
    • jon green earned a badge
    • bill gall earned a badge
    • kor earned a badge
