Knackered battery?
graham k
Hi all
wondering if anyone can help?
first thing in the mornings now since temperature is chilling down a bit my x3 is not turning over as fast as it should ( but still starts)
i put it on charge yesterday and showed fully charged on charger
put multi meter on it said 12.9
started this morning ( but slow cranking)
just went out to check it after been standing for a few hrs 12.5
with engine running 14.4
heres a pic of what’s on there at moment
Morning Graham
Does your service history show any battery change? As the label indicates it is a BMW fitted part, by the part numbers it may be the original so it could well be 14 years old 😲
The Voltage readings seem to show a battery in reasonable condition though at 14 starting current could be giving it a beating. Before jumping in and changing the battery check the engine earth strap and all connections at the starter motor. Magnetti starter motors did have a reputation for pulling huge current as they age so if can get access to a clamp ammeter measure the draw at start. I have seen reports of 800+amps.
12 hours ago, Greydog said:
Morning Graham
Thanks dave 👍
checked again first thing this morning before starting
showed 12.2, no information in service history of any change of battery, I think it maybe the original as well 😱😱
i
2 minutes ago, graham k said:
Thanks dave 👍
i
Think i will take it to my trusty mechanic and get him to test the battery 👍
    2. 14
    5. 14
    • Kiernan earned a badge
    • phil angel earned a badge
    • jon green earned a badge
    • bill gall earned a badge
    • kor earned a badge
