e90 radio not working.
legweed
hello, i have just got a 2006 e90 330d m sport. the radio works but there is on sound,it is not an idrive so there is no amp in the back.so is the amp built in the head unit.
Hi Stephen
I thought there was an Amp in the back (could be wrong and imagining stuff)
If you are not aware there is an online BMW parts list www.realoem.com, put the last 7 digits of your Vin into the search box it will bring up your model. Then search the relevant section there will be small exploded drawings of each component and indications of where they fit.
Obvious stuff checked? No plugs loose fuses blown?
2 hours ago, Greydog said:
Hi Stephen
cheers,i will check the site out.
      New Car New Questions
      Faulty drivers door handle
    4. 0
    5. 14
    • olly530i earned a badge
    • StuMc earned a badge
    • MikeDT earned a badge
