2017 118d msport 3dr
Drew.c
Hi everyone, I’ve just bought a 2017 118d msport 3 dr and the silver trim on the door handles and around the media/nav dial have small scratches probably caused by a ring or such like, does anyone know if you can get repro covers or will I have to get them wrapped.
thanks in advance for any help.
kind regards
Andy.
Hi Andrew
Use www.realoem.com put the last 7 digits of your Vin into the search box it will bring up your model. Then look in the trim section, there you should find the part numbers for the trim sections your looking with the correct part numbers you know a replacement will fit. Then search the internet for replacements.
Hope this helps
