Posted (edited)
6 month old 1 series in workshop again to have a 4th attempt at removing a message telling me that Comfort Access is restricted.  Anyone else having the same issue?  Vehicle is not fitted with Comfort Access !
Edited by S Coleshill
Additiona info
Hi Susan
I have never heard of this issue with the newer cars, however with my 16 year old X5 all the access functions are enabled/disabled by a check box program within the cars control modules. My logic follows that if say "Comfort Access" is checked but the module isn't present would the control module think it was in fault and trigger the light?
Probably way off but it seems logical. Of course you could suggest that to make it an easy fix they just give you Comfort Access (emphasis on GIVE)
On 7/15/2020 at 2:51 PM, Greydog said:
Hi Susan
Just now, S Coleshill said:
Hi Dave.  2 Software updates been installed and 1 new module.  2nd new module now winging it's way in from Germany.  I asked the same question, install Comfort Access FOC.  Cannot be done it has to be factory fitted!!!!   BMW's Ultimate Driving Experience at it's worst.  The saga continues.  Thanks SC
Morning Susan
Can you smell man cow droppings!! Their own Technical Information system gives instructions for the fitting repair etc of the Comfort access
Sadly Dealers vary as do their personnel my local Dealer is pathetic yet the Dealer in Guildford is great both part of the same group!
Maybe start escalating to BMW UK if this fix doesn't work
2 hours ago, Greydog said:
Morning Susan
Good morning Dave.  Will escalate with BMW if the fourth fix fails.  Pattern will be well established by then.  Should I post the latest update when known?  Sue
      Bumpy
    2. 8
      Bumpy
    3. 8
      Bumpy
    4. 8
      Bumpy
    5. 8
      Bumpy
    • Camgriff earned a badge
    • Jlou17 earned a badge
    • JCDenton earned a badge
    • Luke330 earned a badge
