Rear Sensors
John Runcie
I have a towbar on my 2019 X3 got it fitted just after I got the car in February 2019. I had no problems with the rear sensors until recently and when I have my trailer or caravan on the back and go to reverse the brakes come on and you cannot override the sensors like before when I first got towbar fitted, also when you try to reverse onto a slight incline on the ground it does the same the brake automatically comes on
You could reverse no problem before it is just recently this has happened .
Any help appreciated
Thanks John
Hi John
It seems you need the Towbar electric pack tested or changed by whoever fitted it. I take it your trailer brakes are being applied ?
In the UK normally the rear parking sensors are disabled when the trailer electrics are plugged in. I do know that trailers over a certain weight in the US have electronic brake assist is that your issue
Hi John
If you have the Auto H button below the Parking brake if you haven't activated it then I think you have a definite issue with the auto hold system on your car. It is supposed to help when pulling away on hills etc it shouldn't be affected by the fitting of a towbar. Talk to your Dealer they should be able to carry out a diagnostic check,
      Resonator assembly clip
      04 525d
      2e47 & 2e41
      Coolant leak
    5. 2
      Coolant leak
    • Droffilc earned a badge
    • Robbawdie earned a badge
    • Kev Miller earned a badge
    • Jeags earned a badge
