1 series electrics
Lee Williams
hi all got a major headache with my 2006 16ie no indicators elec windows and brake lights,I know sounds like a footwell module problem but had it checked and it's fine batteries good alternator ok had a local garage check it out and they repaired a worn cable at a 380pounds charge and car still off road!! Shes getting on a bit but only has 46000 on the clock Any ideas would be great
Morning Lee
My X5 suffered electrical issues that almost drove me to the edge, the only solution offered was changing modules. Eventually I traced it to one of the earth points in the boot. BMW use a Comb type connector so that many items can be connected to a common point, with mine I removed it cleaned it and the area around it used some electrical connection paste (same as used to seat the chip in a computer) then tightened everything up. Issues gone !! It still took a few months for me to actually believe they were gone for good, so I worked my way through the earth points (there are several) making sure the mounting points were all clean and tight.
Don't know if it apples here but its free and if it works
    2. 14
    3. 14
