Stereo system upgrade
Hi all, I've just upgraded my stereo to a double din, on my X5 e53, done all the fittings works fine, I was aware that I would lose use of the trip computer (stop watch etc) but my odeometer and temp has disappeared from my display, but bottom part still tells me range etc is this normal?
I put a Dynavin unit in my 4.4 when I had that and lost the OBC I read up that others with the standard set up (ie no screen up front retained the MID unit which allows the OBC to function as normal.
My 4.4 had a screen with CD Nav and TV units in the boot which became redundant like yours. I got a mid unit from Ebay then spliced it into the loom left up front and left it in the glove box Dynavin worked great and I could still use the OBC. If I can find it I will post the wiring diagram
Ok thanks
