BMW X5 fitting sat nav
Hi Darrell
Welcome to the Forum , I would check on www.realoem.com to make sure you get a compatible part number for the nav unit and your model you may also need the loom. The nav needs coding to make it work I believe the codes can be downloaded. Not sure if the unit will need coding to the chassis or not but this can be done with INPA and DIS.
Good luck
    2. 14
    3. 14
