washer bottle sensor
chunkyand
Quite often if cheap washer fluids are used there can be a build up of waxy deposits in the reservoir they can clog the filters on the 3 pumps they can also effect the level sensor. So I would drain the tank and take it out then clean it out thoroughly take out the level sensor and make sure its operating OK. It may be the sensor has failed but I haven't heard of one going before but always possible. Have a look at www.realoem.com put in the last 7 digits of your Vin number and look in Electrical systems scroll to the bottom it will show you a diagram and part numbers if you do need a new one.
      Folding mirrors
      Centre console iPhone charger
      Folding mirrors
    5. 3
    • Damion earned a badge
      Reacting Well
    • Stuiggy earned a badge
    • Penguin82 earned a badge
