Lights Go Out Whilst Driving
Daddymac
Is that all lights or just headlights?
How handy are you with a muti meter?
If all lamps relays and fuses have been checked and are OK then you need to get the codes read which should give a clue.
My thinking would be check 1. Bulbs 2. Fuses 3. Relays. 4. Switch 5. Light Control Module. If these are OK get the codes read
I would check all the connections and plugs to the Headlamps especially the earths, get some contact cleaner and spend a little time making sure all the plugs are clean and seated properly. If the lights are HID Xenon don't forget the ballasts (normally mounted under the headlamp)
    2. 4
      Just purchased 320d Touring
    • Astonred earned a badge
      Collaborator
    • amebb went up a rank
    • Conmil earned a badge
