Condensation In Headlight
Guest DazH
Hey Gerard,
Yes, I have heard of this happening a lot. Often caused by bad seals around the unit it's self.
I've had a few motors in the past with evidence of someone curing it themselves. Opening the unit, dealing with the moisture and resealing it with putty/silicon is popular.
Behind the unit, where the bulb sits, there should be a rubber bung going over the opening, are yours present?
Daz
Guest jeffthro
Hi Gerard, yes, as Daz says, It'll be a failed seal. I've not had the problem with my 328, so can't be sure that its as straight forward as it was with my lovely old Primera GT, but I carefully ran around the joint of the headlight unit with a razor blade, separated glass lens from rest of unit, cleaned and dried everything, and then resealed with a thin bead of waterproof silicone sealer.Where possible, tape the joint in place for 24 hours until sealant secure and dry.
Hey Jeff / Daz,
Thanks for your replies, very helpful.
I am gonna have a look at it today to see what the possibilities are with the rubber bungs and seals, whether they are faulty or not.
Will keep you updated
Thanks again guys
  • 6 months later...
If the seals are knackered is there a decent place to get a set of them?
Am I right in thinking theres two parts to the seals? These seem pretty expensive for what they are £23 for the bonnet seal and £27 for the lens seal, and thats per side. Can you get them any cheaper or is it just one of those expensive jobs? Probably be cheaper to buy a full set of used lights.
I recognise the banner around the images from a seller on ebay who i know have put parts up online you should NEVER buy second hand like, i've seen them sell used head bolts :huh: I was desperate once and asked them for a bearing cap (C shaped block of metal that covers a cam bearing) because I lost one when rebuilding. It's no bigger than a playing card and they wanted like 20 odd quid
Well if they claim it's new then i guess it's new.... if it's a good enough price and it's been varified by them that it is (no if buts or maybes) new then go for it fella
Daz
      Exhaust tips
      Insane insurance quotation !
      BWM 216D F46 Issue.
      BWM 216D F46 Issue.
    5. 3
      BWM 216D F46 Issue.
    • Lerxst earned a badge
    • ARoosterinaRoadster earned a badge
    • CJP earned a badge
    • GixxerRaider earned a badge
    • BMW M135i Matt Blue earned a badge
