530I Click Noise From Rear ???
Sam528i
When go over a speed hump (narrow tallish one) when the rear wheels go up and drop down other side there is a loud sharp click type noise from the rear also happened when reversing off drive at an angle and rear wheels where at different angles
Any ideas ???
Just been moted aswell!?
Cheers
Hi Sam am afraid theirs a lot that it could be, get a jack and nip one wheel off at a time and just have a root around, could be a broken spring, a retaining clip may have come loose and a rear pad could be moving around in a caliper, a worn axle bush or a stone guard come loose from a rear disc etc etc, am afraid no easy answer mate, hope your enjoying your 530 otherwise.
Stephen
Stephen
Cheers mate I shall have a look at next chance I get (weather depending haha) and shall update if fine anything :)
And yes I am really enjoying it
If I crawl slow as a snail over the speed hump it don't make the clonk click noise it's only when go over any faster then crawling speed
Think those speed humps may have done a back spring mate, just put your hand under the wheel arch and feel around the bottom of the spring if its broken a spring then theres a good chance its lying at the bottom.
Regards
Stephen
I shall have a nosey when I get chance mate
Thanks for info I shall try see what I can find
