Just Wondering Anybody Own A Super Bike Aswell???
Knowing the Brake are going to work and the tyres are going to point you where you aimed plus stop you is always a big PLUS 🤣 Now you can drive it like you stole it with confidence 🤣 EHJOY Dave -
Front windscreen washers
Hi Donna Welcome to the Forum You have changed just about everything so not much left Is the squirt strong or weak ? When the pump was changed was the filter cleaned or changed ? That leaves either a loose connection (can you hear the pump when it stops squirting) or a Kink in the hose Hope this helps Dave -
8
Well!! It started as a budget query but after a little research and shopping around I managed to get a couple hundred pounds discount off the total price. Originally I was only going to replace the rear set but I also needed a front tyre so I’ve gone all out and purchased two from tyres to match the rear asymmetric 6’s and a full set of discs and pads. So doubled my budget but peace of mind and aesthetically 😊 -
8
Seat Bolster Wear?
As with all modern car seats the drivers side bolster has started to wear, the leather one in mine has just started to loose the leather shine and the stitching has fluffed. Anyone used any really good product to help delay the inevitable, I've currently just started applying a bit of Meguiar's Gold Class Rich Leather 3in1 Leather Cleaner & Protectant. Was thinking of trying a bit of dubbin.
