Hello All.i'm Looking To Purchase A 1Series Convertable.advise Would Be Great
wheel fitment
Absolutely correct my E53 runs 9.5 x 20 Front and 10.5 x 20 Rear and the E70 is as yo say 10 x 20 Front 11 x 20 Rear. Not really necessary on a 4x4 but BMW Designers like the looks 🤣🤣 ( and so do I) Hope you found what you needed Dave -
Front windscreen washers
Morning Donna Has the pump always been like this or has it come on over time? I think I would check the voltage at the Pump connectors so you can compare front and rear perhaps swap the connectors. If the pump action changes when the connector is swapped then the wiring needs checking and the connector needs cleaning with a good electrical contact cleaner. Dave -
9
Hi Dave. In my opinion the squirt is weak, it only reached about a third of the way up the windscreen. The hose has been completely changed from the pump to the first jet, tank and filters have been removed and fully cleaned. It works but weak when the car is not running, but as soon as i start the car the pump works for about 3 seconds before stopping then nothing. The rear is working fine, it's just the fronts. -
wheel fitment
great info! 5 X 120 pattern. I believe the x5 uses 10" front and 11" rear?
