Dash Board = Christmas Tree
Hi folks,
Just had my Suspension struts (F&R), front & rear brake discs, pads, parking brake shoes and fluid all done. Car feels much nicer to drive now.
However on my way to work last night my dash board threw up Tyre Pressure fault, Brake fault & Traction Control fault. No change to cars behaviour.
The mechanic who did the work obviously had to disconnect wheel speed sensors I assume that the wheel speed sensor is responsible for looking after all the functions I mentioned?
If this is the case is it a fair guess that one of the sensors is not connected properly?
If not what else could it be given the work carried out on my car? I had a quick peek into the wheel arch and seen that the box containing the sensor connections had opened and allowed what looked like the Pad wear sensor to fall out (white one). I put it back in and closed the box but obviously that isnt gonna cure the errors.
I have a 2006 (06) E90 320D
Thanks
Andy
Steering angle fault.
  • 4 weeks later...
sounds like your steering is out you need to get it tracked
As per the previous comments, PLUS get a Reset done on the OBDII.
Hey,
Got it fixed it was a steering angle fault.
All sorted
