Sat Nav , Cd Changer Problem
stevemoores1
Does it accept and eject as normal? If it does then throw a cleaning-disc in, might work, might not :unsure:
Is it damp in the boot area? If yes, chances are it'll be buggered... Use a hair dryer ;)
  • 4 weeks later...
  • 4 weeks later...
First check that the disc is a BMW OEM disc these can be temperamental. Have you tried the "disconnect battery for 30mins" trick this resets everything and has fixed many strange gremlins plus make sure your battery is fully charged.
If all else fails you may have failed laser head, not unheard of. You can buy a laser head replacement if you want to DIY or send the unit off for repair if not. Either is cheaper than a replacement.
      Amplifier replacement.
    4. 0
    5. 4
      Front windscreen washers
    • Danny428F33 earned a badge
    • damiansteel earned a badge
    • Loulou earned a badge
    • hermit earned a badge
