E46 Compact Rear Wash Wipe
Malcolmghenderson
Another query already! I didn't get an owners manual with this one and would have thought to operate you would push wiper stalk away from driver.
As nothing happens (or am I trying the wrong operation?) I guess I'll need a new rear wiper motor?
Many thanks & Merry Christmas again
Malcolm
07815 841797
its probably -ooked water gets inside these setting rust at play seizing the insides
try taking it apart clean all the rust out grease the cogs and give it another try
a good hour should have it working from start to finish.
Guest Mr.Beemer
it could be the motor or the wiper switch itself.
if your going to clean & grease it up, check if there is current going to the motor so you know the wiper switch/relay is working or not.
<_<
