Couple Of Problems Need Help With
Sam528i
Hi all I have a
E39 528i sport with all mtec extras
Now it drives spot on tracks straight and don't pull when braking but my problem is every now and then when slowing down I get a loud click type tap noise from front of car quite loud and happened once when turning on full lock
Any ideas?????
Also when first started on a morning the engine seems to run sweet then revs seem to drop right down and back up again not constant but every 20-30 seconds buy when engine up to temperature it's fine and does not fluctuate at all
Any ideas ??????
Many thanks in advance
.sam.
Check all the bushes and suspension legs. Ball-joints too...
As for the idling, why not give the intake and throttle-body a thorough clean... ICV too ?
Cheers mate will jack her up and have a look see what I can find as for the idling I shall whip it all apart when get time and give it a clean only seems to do it till up to optimum temp
Anyone have any ideas on noise seems to do it every time I press brake to slow down
Does not affect drive of car or does not affect braking in any way
Just get a loud click (single click) as soon as I start to brake /decelerate
Does not do it when pulling away only when slowing down and will not recur until I have accelerated and pressed brake again
She is a 2000-X bmw 528i sport mtec ( she has all optional lowered factory sports suspension etc )
Any ideas ?????
Nothing sinister, maybe the caliper-piston "relaxes" more than it should ! :huh:
Does it do this when releasing the throttle (without braking)? If it does then it could be some give in the transmission/shaft/axle, otherwise don't worry...
