Just For You Dabs!
Jayzzle
Thanks mate. Yeah I checked it out, was gonna have a go at taking it off for the shop cus he didn't know what I was talkign about, but I couldn't see how they split? Seems like the middle is 2 solid knuckles welded together.. Maybe I'm just blind but I didn't want to have to take the whole thing off to do it yet so I left it. I have got a problem still though with what I have done, My o/sf is pointing in an entirely different direction to my n/s/f lol, and the brake pad warning light is still on even with brand new sensors fitted? Could it be because neither sensor is actually in the brake pad? Or do I have to reset the light?
Reset is advisable.
The U/J on the prop should have circlips holding the knuckle in place, if not then drop the lot from box to diff (8 bolts) and the centre carrier (2-4 bolts) ;)
An old trick is to disconnect battery for some hours to reset, otherwise a tool in the socket under the bonnet !
Minimal spillage ;)
Some hours you say, you mean like, an overnight job? And there are lots of sockets under the bonnet! Haha. Ok, I'll drop the exhaust (needs changing anyway apparently) and have a butchers at the join, see if I can spot any circlips. If not I'll have at it with the spanners like a lunatic!
On the plus side, I've just had a phone call, my Centre Bearing is at the shop! Excite! Hopefully it will be the right one, collecting tomorrow!
      wheel fitment
      wheel fitment
    5. 8
    • Robbawdie earned a badge
    • hermit earned a badge
    • Neil Mason earned a badge
    • Stuiggy earned a badge
    • jon green earned a badge
