Ecu Options
EXTERIOR MIRRORS AND CAR WASHES
Probably the best way to handle it. I do like the idea keeping a car totally stock. -
Upper control arm play
Morning Gary Welcome to the Forum At 17k I would suspect that the Bushes are OK but check that the Upper Control Arms are torqued correctly The supplying garage should take care of that with no argument even if it means new upper arms, as these are faults that were are present at sale. Even if it is outside their 60day warranty the sale of goods act is on your side as clearly the car in its current condition isn't suitable for purpose Push Good Luck Dave -
Hi and thanks for responding to my post. I have seen two Facebook posts and they are rather blatantly pointing out the problem. I have no idea whether BMW have actually commented let alone actioned the post but I kinda believe they have just looked the other way ! Re your 430i it may be a good idea to get her up on a ramp of your friendly garage and have a closer look or tap it (pun intended !). Let me know if you find out soon. Cheers -
Hi folks I purchased a 2025 BMW 220i with around 17k. Car was pulling slightly so had 4 wheel alignment carried out and in spec. While up on ramp it was noted that upper control arms on both sides front could move slightly back.and forth. Albeit minimal but can still move. Is this normal or do I have issues with ball joints or bushes or need new arms under 60 day warranty. Must say car is still pulling and there are no unusual noises -
12
Just bought a Porsche
You have a "list of jobs" too 🤣 I tried confusing her by starting at the bottom I thought if she saw ticks near the bottom 😅 Top tip it didn't work 🤣- 2
