How Do I Program A New Key Fob
2011 bmw 328ix drive shaking at 45 miles ahour and at other
Hi Brandon. first things first. Change the wheel for the spare.. if it stops, it’s the wheel. Next, check the wheel alignment. Then check for uneven wear across the tyre. You might have bent a suspension component. Check to see if a spring has broken? -
Traction control warning
Hi John Welcome to the Forum The most common cause for the DTC/DSC warning is a failed ABS wheel sensor or a Fault with the ABS unit possibly a fault with the Steering angle sensor. A Diagnostic Scan with a BMW capable scanner would verify the issue, if it is a wheel sensor it is a straight forward change if an ABS unit there are several repair companies in the UK who repair them far cheaper than a new unit. Dave -
Dear All, To get my 740L through the Swiss MOT I need to stop the warning that DTC is not available, every time I power up. If the warning doesn't come up, I can get it through. If not, my garage says it will not be accepted. They tried to get a replacement for the steering wheel insert, but failed. Can anybody tell me if there is a way simply to stop that warning coming up? Thanks a lot! Best, John -
Rear knocking
Hi Eduan Welcome to the Forum First place to check is Sub Frame mounting Bushes, on a 19 year old car they will be tired. In Order to check rear suspension bushes the Air suspension has to be deflated not a difficult task but essential. Again I would expect a 19 year old car to have a lot of wear and is probably in need of a refresh. Tip if refreshing the suspension get new camber bolts for adjustment mark the old ones position with a bit of Tippex so it all goes back as original. If the suspension is good then drive shafts, diff, Propshaft are next for checking Dave
