Bmw E39 Starting Problem
BMW 520I
When you run out of petrol, the fuel rail and pipes lose pressure. When you try to crank again, it takes quite a bit to prime them again.
If you have a weak battery, you may of ran it down priming the fuel system. Jump starting might be an idea...
the only real threat you have of damaging the car by letting the fuel completely deplete is the fuel pump being damaged. It is lubricated by the fuel so driving it without fuel running through it may damage it if it is already weak. Unliekly but the only theory I can think of...
there are many theorys and one of them often pokes it's head up. "Sucking gunk from the bottom of the tank when your fuel runs low". This is not exactly true as the fuel is taken from the bottom of the tank anyway. It may be worth changing your fuel filter for the sake of it though...
Daz
      New member
      2016 M240 "lumpiness" at steady low speed
      645ci coolant
    • davecullen6 earned a badge
    • Sussex Kev earned a badge
    • Clunk 84 earned a badge
    • LRR earned a badge
    • BobW earned a badge
