Armrests
Charlee
Hello all! I want an armrest in my car, Adams compact has one and he's said I can have it :D His is a 97 an mines a 2000. Does anyone know if its possible? Do I need to swap the whole centre console? Or can I just take the back section from his where the armrest attaches? Thanks in advance!
Usually if the arm rest is attached to the seat you CAN install them from another donor seat but it is labour intensive. Like the seat, the centre console can also be swapped but again, labour intensive.
Ultimately, If you didn't want to dedicate the time needed to remove super glue from your paint work you will definitely not want to take on this task as the benefits don't balance out with the labour unless your a dedicated spanner head :)
If you DO want to take on the task, I'LL ASSIST but that's simply because I find it hard to say no when something interesting is to be done..
HTH
Daz
      Engine cut-out on idle.
      Amplifier replacement.
    5. 3
    • Allan Wilson earned a badge
    • Danny428F33 earned a badge
      Reacting Well
    • damiansteel earned a badge
