Warped Disks On A 335D
MarkBryan
Hi
I am new to the club and I am in need of some help.
I have a 335D Estate on a 57 plate. About 3 months ago I found there was a vibration through the steering wheel when braking. I took the car into the local garage and they changed the pads and disks. Just over a month later the same fault happened again and the disks were replaced under warranty.
I am a month down the line with the 2nd new set of disks and the vibration is happening again. The mechanic said I have not let the disks bed in properly and have braked to hard????????
What could be causing the disks to warp?
Please can you help?
Thanks
Mark
      Engine cut-out on idle.
      Amplifier replacement.
    5. 3
    • Sbannas earned a badge
    • Allan Wilson earned a badge
    • Danny428F33 earned a badge
      Reacting Well
