Hi Iam A New Guy,
Can someone please enlighten me on how the auto grill system is supposed to work? My 2018 M40i has this system fitted but I don't recall seeing it closed I understood that it closed during cold weather to allow the engine to warm up quicker. -
Thank you for your interest in this topic. There is some hope that a solution can be found through joint efforts) I eliminated the oil feed pipes.Since the first thing I did was replace the sealing rings there. I am attaching a few more photos showing the leaking area. -
Hi Dave, Sure, realoem. Part number (steel gasket) is 11628576287. and according to the second drawing (please see attached), this is the EGR Line Gasket. Andrew -
Hi Andrew Are you using www.realoem.com ? The drawing looks like it or is that from the Internet? Is the turbo fitted OEM ? Dave
