I've Just Bought My First Beemer - Help Required!
wheel fitment
Hope this has not been beaten to death already. can I use20" x5 wheels on a 2015 650I X? thanks. -
8
Knowing the Brake are going to work and the tyres are going to point you where you aimed plus stop you is always a big PLUS 🤣 Now you can drive it like you stole it with confidence 🤣 EHJOY Dave -
Front windscreen washers
Hi Donna Welcome to the Forum You have changed just about everything so not much left Is the squirt strong or weak ? When the pump was changed was the filter cleaned or changed ? That leaves either a loose connection (can you hear the pump when it stops squirting) or a Kink in the hose Hope this helps Dave -
8
Well!! It started as a budget query but after a little research and shopping around I managed to get a couple hundred pounds discount off the total price. Originally I was only going to replace the rear set but I also needed a front tyre so I’ve gone all out and purchased two from tyres to match the rear asymmetric 6’s and a full set of discs and pads. So doubled my budget but peace of mind and aesthetically 😊 -
8
