Red Fluid Leaking
Rambo30
After reversing up my drive thats on a slope i noticed that there was red fluid leaking out from the front end of car and as im no mechanic i wanted to know what it could be. Any ideas?
  • After having a good look under car and not seeing anything (but then im no mechanic), checking the levels on everything needing liquid are all fine and no warning lights flashing up and staying on on dashboard, I dont know what else it could be.
As said above prob power steering fluid or trans< i have a slight leak on my 7 which is from the power steering but check the levels it doesnt show it as only slight but over a month i will notice a slight drop but as above say could be the trans as well as both are red
BMW's are renowned for the pipes to slightly weep up to the Power-Steering Reservoir ! HTH ;)
There are only TWO fixes to this issue... New pipes (expensive) or whack some Jubilee clips over the connections !!
That is exactly what my 7 has but is so slight not really worried as hardly goes down on fluid
    2. 14
    5. 14
    • Kiernan earned a badge
    • phil angel earned a badge
    • jon green earned a badge
    • bill gall earned a badge
    • kor earned a badge
