Hello
im having this issue where during driving the car changes to neutral , has happend twice now. car is x3 f25 20d -
Inherited an R56? 2009 ONE
I’m guessing this one hasn’t been serviced since it was born! … I took the filter box apart and it needs replacing. Someone has tried to fix it before, but it’s beyond alive now! Haha. the bootlid needs either pushing out or replacing, as does the rear bumper after it got into a fight with a bus… and a rear light… apart from that, it seems well. 😂 -
Great little cars Stu A neighbour has one and she loves it they do need a good annual service though, seen several that were unreliable due to not being used much and waiting for the service indicator to tell them it needed service? One was 5 years between services? You will also need a good code reader Dave- 1
Morning Dan Welcome to the Forum As it isn't a BMW Part I am not sure there will be help here, unless a member on here has come across the same issue Maybe Google to see if there is a Harmon Kardon Forum to see if they have more information Good Luck Dave
