Advice Please
hi8prt
hi all, new to the site as i have just purchased a 02 series 3 320td and would like your help
1 where can i find a workshop manual for the car preferably on cd that will run windows7 64bit ?
2 what oil should i use as i plan to change the oil castrol recommend 0/30 fully synthetic what do you think as the car has 122k+ on the clock ?
3 i am about to check and replace the swirl valves as i've been advised to do so asap whilst doing so is there anything i should whilst i've got this dismantled such as any filter ?
4 when i removed the engine cover at the front of the engine i noticed what i believe to be a pipe missing what are your thoughts please IMAG0963.jpg
thanks in advance for any help given " CHEERS " Phil
Hi mate work shop manual are available on eBay in CD format
thanks for the reply but all the one's on ebay are quoted as not for 64bit which my laptop is "cheers" Phil
      650i crank no start
      Parking Break Failure
      650i crank no start
      Suspension upgrade
      Suspension upgrade
