Tv Module
handymankev
Hi, i bought a x5 3.0d s 2006 about two weeks ago there was no mention of it have tv on it but after nosing about under the spare wheel i found it has got the tv tuner fitted but not showing up on the menu. i unpluged and then pluged back in the fan started for a about two seconds and stopped and help on want to do would be great.
Anologue Module will be useless now !! A BMW Digital unit is available but expensive... Best to buy an aftermarket receiver and connect to AV socket...
BTW Your other Identical posts have been unapproved...
Sorry to hijack this thread but I'm also looking to install TV in my 04 3.0d. can I just plug the digital box straight in? Is that what you mean by AV socket? Guessing this is in rear of headunit?
Also, any tuners you would recommend?
Sorry for so many questions. Thanks in advance
Alex
By all means use the AV socket unless you can retro-fit a newer BMW Digi Module...
As for advice on aftermarket mobile DTV, I cannot really suggest any particular unit at this time as it can be an individual preference... Have a scout round Ebay ;)
      New member
      2016 M240 "lumpiness" at steady low speed
      645ci coolant
    • davecullen6 earned a badge
    • Sussex Kev earned a badge
    • Clunk 84 earned a badge
    • LRR earned a badge
    • BobW earned a badge
