Oil Leak
Mook
Hi,I'm a new member to the club,got a 325 ci auto that has just started to develop an oil leak, can't see where it is coming from, any ideas as to the most common places to look out for?
Thanks.
Try to determine what type of oil is leaking... Tranny/Power steering oil or Engine oil?
Engine oil - Usually, either the Rocker gasket, Head gasket or Sump gasket, crank/cam seal...
Tranny/Power Steering oil - Top or side of gearbox or rear output shaft seal... Power steering reservoir pipes or rack...
Just a few places for you to look :unsure:
Thanks DABSY, it,s slightly worrying, it could be a quick painless fix, or a very costly painfull one.
Nahhh bit of sticky tape and your good too go ;)
Get back to us with the location and someone will help you resolve it. Dont worry... (Yet)
Daz
      Coolant leak
      Coolant leak
      Coolant leak
    4. 5
      2e47 & 2e41
    • Kev Miller earned a badge
    • Jeags earned a badge
    • olly530i earned a badge
    • StuMc earned a badge
