Parking Sensors
Park assist not detecting spaces
Morning Nigel Welcome to the Forum A diagnostic scan will confirm the issue so before spending your Hard Earned that would be my course of action. Either find a BMW specialist or a good independent garage that has BMW capable diagnostics (Foxwell, Autologic, iCarsoft) Or if you are a DIY fan then buy your own Google BMW Diagnostic Software for less than the cost of a single visit to a Dealer you could have your own. Dave -
Park assist no longer detects parking space. I think I have narrowed it down to Park assist control module. I have a used replacement. Is it plug and play or will it need to be programed. If so how. I hope I don't have to take it in to BMW. thanks. Oh,just remembered is there an easy way to get surround off luggage hook in boot so I can remove panel? -
Water Leaking Into Rear Footwell
Morning Chris Welcome to the Forum That's a lot of water 😢 I fixed a 5 series for a friend of our son his was no where near that bad though. With the 5 series the rear door card had been removed at sometime and the vapour barrier was missing that added to the drains in the bottom of the door being blocked. The bottom of the door was just full of water. When it rained or he went through a car wash it overflowed and filled the footwell. I cleared the door drains a lot of water was held in there I dried it out with a heat gun (checked the roof drains as well they were OK) Fitted a new vapour barrier took out the carpet and sound deadening thick pad which was sopping, gave them a spin in the washing machine then dried in the sun. While they dried I jet washed the car to check for leaks (none found) so I replaced the Door Card sound deadening and carpet he has had no issue over the last 3 years. With luck that will be your problem 😁 If it isn't then you have a serious leak under the car or in a seam Hope this helps not hinders Dave -
Looking for some advice, every time it rains my rear passenger footwell floods really badly. Took approx 6 litres of water out yesterday. Can’t seem to find the source and wandered if there are any areas that are prone to leaks? The water seems to appear from nowhere, the door seals, window seals, A/B/C pillars, boot, front footwells and roof linings are all bone dry. Even the footwell above the ankle level are dry, indicating water isn’t coming from the door area. The water gets in even with the car being stationary. The only two things I can think of are the sunroof drains (as I believe they expel water in the region of the rear footwells) or the aerial (but would assume both footwells would have some water in, not just the passenger side) any pointers would be much appreciated as it seems to be getting gradually worse. TIA. -
2003 318i SE Touring - Advice
Hi Enthusiasts! I'm the third owner of a 2003 BMW 318i SE Touring Car, 110,000 miles, that I bought from used approved Peter Vardy in Edinburgh in 2010. I've absolutely loved it! But it's coming to the end of its life, I fear. In particular the offside rear bracket holding the brake hose has completely corroded, so the garage (BM Motorworks in Stockport) has had to 'improvise' to attach it to get it through the MOT. There's some paint 'bubbling' over the wheel arches and general oil leaks - the usual for a car of that age. But it just got through it's MOT for another year, although with a load of advisories. I think it has a full service record - I got the inspections done at BM-Tec in Salford, and then last one at BM Motorworks last year. It's still a great drive, the interior is in great condition and all the electrics (apart from CDP) work great. So it pains me to let it go. But I don't have much mechanical knowledge and I think it's getting to the stage where, if it keeps going, it needs someone who can give it some TLC. I want a car I don't need to worry about. So I'm writing to ask if there's a forum where enthusiasts might be interested in buying it, someone who knows what they are getting into with one of these great cars? Any advice welcome! Thanks, Max
