Correct Engine Oil
Hi there,
I have a BMW 316i, with 106,000 on the clock.
I need to top up the engine oil, although it only had oil put in during its last service in February, it appears to have run out - long running problem.
What is the best oil to use?
I do think I have a leak of some sort because it seems to run out of oil, but I cant see any on the floor once the cars moved- if anyone has any suggestions they'd be gratefully recieved!
Many thanks
Jennifer
It must be "Burning" it then !!
It's not advised, but with older engines I tend to put "Thicker" oil in... This usually slows down the inevitable...
I put Diesel engine oil in a petrol engine as it has tougher qualities !
I put recycled oil in my van I have a drum under it at night what comes out goes back in the morning :-)
Ahhh, Duckhams LOL
  • 1 year later...
  • 6 years later...
NO. Don't ever add the wrong oil type. Solve the problem instead: The 316 is renowned for valve stem oils seals going. They perish. Get them replaced then drop the oil and filter. Add fresh corect oil and new filter.
      Folding mirrors
      Centre console iPhone charger
      Folding mirrors
    5. 3
    • Damion earned a badge
      Reacting Well
    • Stuiggy earned a badge
    • Penguin82 earned a badge
