Down Pipe Bracket
5 series g31 touring
Morning all after having a M135i xdrive for nearly 5 years I decided to have a change and get myself a 520d touring xdrive 2021. Cant compare the two together as both totally different but great cars. -
Recommended body shop in south London for E39
Hi guys. My son has a 2002 E39 530i Sport which needs some remedial work to remove rust off the sills. Can anyone recommend a good body shop in south London, preferably a BMW specialist? -
2011 bmw 328ix drive shaking at 45 miles ahour and at other
Hi Brandon. first things first. Change the wheel for the spare.. if it stops, it’s the wheel. Next, check the wheel alignment. Then check for uneven wear across the tyre. You might have bent a suspension component. Check to see if a spring has broken? -
Traction control warning
Hi John Welcome to the Forum The most common cause for the DTC/DSC warning is a failed ABS wheel sensor or a Fault with the ABS unit possibly a fault with the Steering angle sensor. A Diagnostic Scan with a BMW capable scanner would verify the issue, if it is a wheel sensor it is a straight forward change if an ABS unit there are several repair companies in the UK who repair them far cheaper than a new unit. Dave
