BMW M135i 2020 Ticking / Rattling noise when accelerating
Hi, I've just purchased a 20 plate BMW M135i. It's really nice, everything is in good condition but the only thing that's bothering me is there's a tapping / clicking / rattling noise when I'm accelerating coming from what sounds like the engine bay somewhere near the drivers side front wheel. I have had it in the garage and they said there's absolutely nothing wrong with it. I'm just wondering if anyone else has had the same issue, if so if you had managed to work out what was causing it and if required what was done to fix it? I don't think it's anything major in terms of the engine or anything failing. It's more just irritating, so if I can fix it I will do. Thanks, Niall -
I am looking at buying a 2014 135i anything to look out for
Hi all, As you can see i am new to this forum. I am looking at buying a 2014 135i auto. Its got FSH, totally standard, with 77k on the clock. The guy who is selling it has receipts for loads of preventative maintenance, coolant, oil gaskets etc. Does the gearbox need servicing? if so, does anyone know what the cost is. Thanks in advance. -
BWM 216D F46 Issue.
I am getting the following issue for my turbo. Totally my turbo is not working. I am the 2nd owner and the current milage i took over from 90k and now under me, it is 175k. My mech says it highly likely is a turbo charger issue with the internal valve being stuck. Any one encounter this issue? -
Engine bonnet release latch not working properly
Hi, My 120i bonnet release latch is difficult to open the bonnet. It just started causing me problems. The handles comes right up but does does open the bonnet, I need to try it about 5 times and I am worried I will break the plastic latch. My question is there a way to tighten the cable or should I just replace the cable, if so how easy is it to replace myself. All suggestions greatly appreciated. -
New member
Thanks very much for welcome, I've done the history search via BMW dealer and there's none there! As the one previous owner was a sales manager for a large franchise, I'm thinking they did the servicing but maybe didn't have access to the BMW system to update it. I'm getting it serviced at main dealer next month and that will allow me to purchase a warranty from BMW or possibly elsewhere as BMW warranty dept pretty useless so far. Just back from 3 days in Yorkshire and it is an amazing car to drive for sure! Cheers Dave- 1
