E36 Engine Swap Gone Rong
Driftslut2010
you need to get hold of the ecu for that engine also there is a small black box which is for the imobiliser just under the steering column i had the same problem the only way i solved it was buying a donor car with the engine running i swaped the ecu and wiring loom + the little box under the column the car started straight off the key
      wheel fitment
      wheel fitment
    5. 8
    • Robbawdie earned a badge
    • hermit earned a badge
    • Neil Mason earned a badge
    • Stuiggy earned a badge
    • jon green earned a badge
